Atlantis Word Processor 4.3.3 (beta)
Atlantis Word Processor 4.3.3 is available for betatesting.
This version introduces a redesigned “Tools | Options...” dialog with many additional settings and customization options:
For the information on the new settings, press F1 in the new Options dialog, or click here.
You will also find new options in the toolbar customization dialog (“Tools | Customize | Toolbars...”):
Setup file of Atlantis Word Processor 4.3.3.0 (size: 2.9 MB) (build b3, released on Aug 6, 2023)
Re: Atlantis Word Processor 4.3.3 (beta)
There are also new options in the “Save as eBook” dialog:
For the info on these new options, see this Help article.
One more new option on the "General" tab of the "Tools | Options..." dialog:
A new command in the “Search options” menu of the Find/Replace panel of the Control Board:
and the new options on the “General” tab of the “Tools | Options...” dialog:
New options in the “Tools | Quick Personalization...” dialog:
dougrrr
Post by dougrrr »
OMG! I just saved my memoir in epub and mobi.
Damn, you guys are GOOD!
Alan
Post by Alan »
Since updating to Beta b3 I have noticed that Select whole words automatically is not working for Strikeout and language none (that is all I have used so far). With the insert point inside a word and the word NOT selected neither of those 2 functions are applied to the whole word. When I do have a word selected both those do get applied.
Alan
Atlantis 5
dougrrr wrote:I just saved my memoir in epub and mobi.
Congratulations, dougrrr!
Alan wrote: Since updating to Beta b3 I have noticed that Select whole words automatically is not working for Strikeout and language none (that is all I have used so far). With the insert point inside a word and the word NOT selected neither of those 2 functions are applied to the whole word. When I do have a word selected both those do get applied.
"Select whole words automatically" is about selecting text with the mouse, not about formatting text. You might wish to enable the "Format without selection" option instead on the same "Edit" tab of the "Tools | Options..." dialog.
Alan
Post by Alan »
Thanks admin,
You are right and I was wrong. Now if I only knew how that became unchecked.
Alan
Atlantis 5
