Recently closed document menu please
graatch
Post by graatch »
When you're hard at work, and your document bar is full of tabs, it can be very easy to accidentally tap an x on something and with the names mostly hidden it can become unclear what got closed, which makes you lose time and maybe confuses one. If we could get a recently closed (in Atlantis) menu to reopen the files that would be very helpful. ESPECIALLY since reopening Atlantis and having the saved tabs state restored does not put the tabbed files into the recent documents list, only the filesystem Open does that it seems.
Re: Recently closed document menu please
Atlantis will probably soon offer this menu.
By the way, you can resize the Document Bar to make the document buttons wider.
The "Recently Closed" command is available in version 4.4.5.2:
https://www.atlantiswordprocessor.com/e ... _5_002.htm
