Atlantis Word Processor in your language
Atlantis is adding support for language packs for its interface. The entire user interface of Atlantis can now be translated into virtually any language.
If you are willing to help with translating the Atlantis user interface into your native language, please click here:
https://www.atlantiswordprocessor.com/e ... _packs.htm
rafal
Re: Atlantis Word Processor in your language
Post by rafal »
Finally! Thanks!
rafal
Post by rafal »
Hi
I started translating, but today I noticed that there is a new update for Atlantis. Does it change or introduce any new text to the translation? Will you inform about such changes in the future? Will I lose the "Lang" folder when updating Atlantis?
This is not a problem. You should keep updating your copy of Atlantis. Atlantis will never modify your "test" files.
Any future version of Atlantis will be able to use your language pack even if it is incomplete (missing files or resource items) or not completely translated. New releases of Atlantis will not change existing text resource items. They will add new items as needed. A complete log of new text resource items will be available on our site in the future. So, it would be easy to update previously created language packs correspondingly. But Atlantis 4.4.1.6 (and higher) can reliably use language packs that lack certain resource items. There are no new resource items in 4.4.1.7. But if version 4.4.1.7 had introduced a new message, you could still use version 4.4.1.7 with your "old" Polish language pack. Atlantis would simply display the new message in English (Atlantis would retrieve the new message from its built-in English language pack).
Backing up your "Test" folder regularly is a good idea in any case.
To make sure that Atlantis is using your language pack from the "Lang\Test" folder, you can choose the "Tools | Options..." menu command of Atlantis (4.4.1.7 and higher), and click the "Accessibility" tab. At the top it should say "User interface in test mode".
rafal
Post by rafal »
Thanks for explaining. After the update everything works fine. A list of translation changes published on the website will be very helpful, especially when the translation is ready.
Jojav
Post by Jojav »
Good afternoon. How can I get the Atlantis Word user interface in Spanish? Thanks for your help
There is no Spanish user interface at this point. It will be available when someone volunteers to create it.
The French and German UI language packs have been released:
https://www.atlantiswordprocessor.com/e ... _2_000.htm
Now there is a log of changes to the UI resource files of Atlantis:
https://www.atlantiswordprocessor.com/e ... ks_log.htm
Any changes to the resource files will be logged there.
rafal
Post by rafal »
Due to the release of the Polish translation, I am closing my project.
