A positive feedback for the new portability features
Moonlight
Post by Moonlight »
With version 4.4 new portability features have been established.
I tried out some of them, e.g. the possibility to create a portable copy of Atlantis as a clone from the existing non-portable one (either in order to use both of them or in order to replace the non-portable one).
This and various other procedures which I have tested worked perfectly without any issues. And once more the Help section of the Atlantis website is an excellent source as it explains all new possibilities in a clear, understandable way. The details about portability can be found here:
https://www.atlantiswordprocessor.com/e ... rtable.htm
and here (as far as migration to a new PC is concerned):
https://www.atlantiswordprocessor.com/e ... rating.htm
So I thought to write these positive words in order to appreciate the great work that was done with this (as with every) new version of Atlantis. :wink:
Re: A positive feedback for the new portability features
Thanks for taking the time to share your thoughts.
