Atlantis Word Processor 4.3.1 (beta)
Atlantis Word Processor 4.3.1 is available for betatesting.
This version is a minor release with a new accessibility option on the “General” tab of the “Tools | Options...” dialog. You can now increase the size of text and controls of the entire Atlantis GUI:
Setup file of Atlantis Word Processor 4.3.1.0 (size: 2.9 MB) (build b2, released on May 22, 2023)
Re: Atlantis Word Processor 4.3.1 (beta)
Version 4.3.1 has been released as a public version. Please click "Help | Check for Updates..." to replace the beta with the public version.
