How Do I Backup Customized Menus & Toolbars?
Jdanniel
Post by Jdanniel »
Hello.
I just began dabbling with Atlantis today, and so far, I am very impressed.
Here's my question:
I've customized a few menus and toolbars. I'd like to know which file(s) I need to backup, in the event I choose to format my hard drive and reinstall my software.
(I do this fairly often--I dabble with all sorts of things, and sometimes it's just easier to format-and-reinstall than do a full system restore.)
Which files contain the alterations? If I back them up and restore them where they originally where, will the revised menus & toolbars appear, or do I have to instruct Atlantis to recognize them?
Thank you very much! J. Danniel (Please call me Jd.)
The "Tools | Options..." dialog of Atlantis has the "Save to File..." and "Load from File..." buttons. The "Save to File..." button allows to save all the Atlantis settings (including menus and toolbars) to an INI file. The "Load from File..." button allows to load the settings from such an INI file.
