Tab weirdness.
Burai
Tab weirdness.
Post by Burai »
Noticed a problem since the last upgrade, and I'm wondering if anyone else has seen it ... when I load files with default tab stops (0.5"), they're displayed with 0.25"-wide tabs instead. New tabs show up correctly, and when I start typing on an existing paragraph it often readjusts the tab to the correct spacing again (for just that paragraph).
Double-checked the settings, and it definitely says the default tab spacing is still 0.5".
Please send your document which displays wrongly in Atlantis (you can attach it to your forum post).
Burai
Here's a sample file.
Post by Burai »
This file has showed the problem before (though not always -- see below). It's basically a dummy I wrote as a test: if it displays correctly, you get a neatly spaced table with a colored stripe across the entire top, but when the bug pops up, the table's scrambled and the stripe only extends halfway. (Or appears to -- I think the tabs are saving correctly, they're just not displaying right all the time).
Unfortunately, it also seems to be a Heisenbug: it doesn't always show up (even in the same file), and I haven't narrowed down when it will or won't. Hence my question as to whether anyone else has had a similar experience.
Number Test.rtf
(2.23 KiB) Downloaded 710 times
We have managed to reproduce a situation when tab characters do not have proper width. For this, the default tab width should be changed through the “Format | Tabs…” dialog. Then if you use Undo/Redo, the default tab width is not switched on the monitor screen. As I understand, you meant this. This bug does not affect the document contents indeed. If you simply re-open your document, the display would be OK. A fix will be included in the next build or release of Atlantis. Thanks.
Re: Tab weirdness
Greetings--
I have created a similar document using columns instead of tabs.
Please have a look.
Numbers (3).rtf
(2.07 KiB) Downloaded 691 times
