Pegasus mail
Pegasus mail
Post by 1953 »
I would like to configure Pegasus to be used with Atlantis, (but... and this is a very big but) first is a none techie able to do it and if so in very easy basic language how? Many thanks.
Re: Pegasus mail
Atlantis is “email-client-indifferent” application.<br><br>Atlantis uses so called “Simple MAPI” interface to communicate with the default email client. Atlantis could be used with nearly any email client supporting “Simple MAPI”.<br><br>To use your email client with Atlantis,<br><br>a) your email client should support “Simple MAPI” (should be “Simple MAPI”-compliant),<br>b) your email client should be configured/specified as the default “Simple MAPI”-client.<br><br>If your email client does not support “Simple MAPI”, I afraid that you could not use it with Atlantis. I personally do not use Pegasus. But as I know it does not support “Simple MAPI”. Anyway you could contact its authors for more information.<br><br>The best “Simple MAPI” client I know is Microsoft Outlook (Express).
Max_Quordlepleen
Re: Pegasus mail
Post by Max_Quordlepleen »
1953, it could scarcely be easier. If you are running &nbsp;Pegasus 3.12 &nbsp;just run the program wpmmapi.exe, and select "Simple MAPI", and it will install the necessary MAPI support.
Salaam alaikum, noho ora mai
1953
Re: Pegasus mail
Post by 1953 »
Max is it the same for version 4, or is 3.12 better?
Max_Quordlepleen
Re: Pegasus mail
I use 4.01, and Atlantis "Send by Email" works just fine, so Simple MAPI must be configured in my Pegasus. Whether it is automatic, or was the result of a choice I made during setup, I can't remember. :-[<br>I shall ask around and get back to you on that one.
Max_Quordlepleen
Re: Pegasus mail
1953 wrote:<br>Max is it the same for version 4, or is 3.12 better?<br>
<br><br>It is the same in 4 as it turns out. Look for wpmmapi.exe in your PMAIL folder, &nbsp;run it, and select Simple MAPI, as in the screenshot here:<br>http://maxqnz.com/screenshots/mapi.gif After that, you should be away laughing. <br><br>POST-EDITSee http://makeashorterlink.com/?E1FA22D7 for another important note on Pegasus and Atlantis.
1953
Re: Pegasus mail
Post by 1953 »
Thanks Max, you have saved me a lot of messing about trying to figure it out.
Max_Quordlepleen
Re: Pegasus mail
<br>
1953 wrote:<br>Thanks Max, you have saved me a lot of messing about trying to figure it out.<br>
<br><br>You're welcome - did it work?
1953
Re: Pegasus mail
Post by 1953 »
Yes  :)
