Headings
Andremusic
Headings
Post by Andremusic »
I have a question about the heading option in the control board. I am using it to make the chapters in my story and it works fine, but when I click on a heading it doesn't go to the position in the text of the heading but on the last line on the page before. How can I fix this?
This might happen if a heading includes a manual page break. A manual page break does not create a new paragraph. The text before & after a page break still belongs to the same paragraph. If it is not your case, please send a sample document (send by email to betatesting@AtlantisWordProcessor.com, or attach to your forum post).
Andremusic
How then do I make a different kind of page break, opposite to a manual break, so this problem will not happen?
Re: Page breaks
Greetings--
Set "Page break before" as part of the Paragraph properties of your Heading style. Do not use "Ctrl+Enter" to insert page breaks.
Also you might want to take a look at the following newsgroup thread (be careful to copy the whole URL):
http://groups.google.com/group/microsof ... 570df8407d
