Misspell Underline
Guest
Misspell Underline
Post by Guest »
Arthritis Relief Formula? ?
Active ingredients: Bryonia alba 4x, Cimicifuga racemosa 4x, Rhus toxicodendron 4x, 12x, 30x, Coffea cruda 6x, Colchicum autumnale 6x, Dulcamara 6x, 12x, 30x, Apis mellifica 9x, Rhododendron chrysanthum 12x
This was copied from the net. Is there a way to remove all misspelt wavy lines from beneath rightly spelled names. I do not wish to add these to my dictionary. I do not want to disable the misspelled underlines. I hope you understand what I mean. When I click on spell check is there a way to ignore all, not just the mispelled word but all underlined words all at once. in onother words ignore all underlined misspelled words with one click.
Re: Misspell Underline
Guest wrote: Arthritis Relief Formula? ?
Greetings--
Here is how to proceed:
1) Select the whole text/paragraph(s) that you do not want spellchecked/underlined.
2) Launch the "Format | Language..." command.
3) Choose "<None>" as language.
4) Click "OK".
emcat
Misspell Underline
Post by emcat »
Guest wrote: Is there a way to remove all misspelt wavy lines from beneath rightly spelled names. I do not wish to add these to my dictionary. I do not want to disable the misspelled underlines.
I have a similar request. I, too, work with many words I don't want to add to the dictionary, yet must copy and paste them. Atlantis does not permit copy/paste with words that it thinks are misspelled. I don't care about turning off the wavy lines under the word, I just want to be able to copy and paste. Rather, to be able to do with those words, what I can do with any other normal word. Is this possible?
Thank you, Maggie
emcat wrote: I have a similar request. I, too, work with many words I don't want to add to the dictionary, yet must copy and paste them. Atlantis does not permit copy/paste with words that it thinks are misspelled.
Greetings--
When words are underlined by Spellcheck-As-You-Type, they cannot be copied with the usual right click "copy" command.
In such cases, you have to select the word first, then use either
1) the CTRL+C hot key.
2) or the "Edit | Copy" main menu command.
Maggie
Post by Maggie »
Greetings--
Yes, I had noted that. When copying these words constantly it takes many keystrokes where the right click select|copy is so quick...
But thank you for the zippy reply :) It's appreciated.
Maggie
Re: Misspell Underline (2)
Maggie wrote: Yes, I had noted that. When copying these words constantly it takes many keystrokes where the right click select|copy is so quick...
Maggie
Greetings--
Do you really find "CTRL+C" so cumbersome?
The spellcheck right-click menu of the next build/release of Atlantis will include the "Copy"/"Cut"/"Paste"/"Delete" commands (when you right-click the selected underlined word):
emcat
Post by emcat »
admin wrote: The spellcheck right-click menu of the next build/release of Atlantis will include the "Copy"/"Cut"/"Paste"/"Delete" commands (when you right-click the selected underlined word):
Thank you! Wow, a lightening-fast solution that will make my ongoing chronology much easier.
Thanks again,
Maggie
