Help file
Alan
Help file
Post by Alan »
I am doing Atlantis Ocean Mind 1.5.2.0a3 Beta testing without having Ocean Mind on my computer, this means I don't have the help file, Atlantis.chm. Is there some place I can download this file?
You could download the Setup file of the latest public release of Atlantis Ocean Mind (1.5.1.4), and install Atlantis (including the Help system) to your PC. Then override "C:\Program Files\Atlantis\Atlantis.exe" with one downloaded from the Betatesting page.
R: eHelp file
arr242 wrote: I am doing Atlantis Ocean Mind 1.5.2.0a3 Beta testing without having Ocean Mind on my computer, this means I don't have the help file, Atlantis.chm. Is there some place I can download this file?
Hi!
If you really want to help us test the latest beta version of Atlantis Ocean Mind, please follow the instructions on the following page:
http://www.rssol.com/en/html/atl10_beta/main.htm
This means downloading the trial shareware version of Atlantis first from the following page:
http://www.rssol.com/en/html/download/ocean_mind.htm
Use the online install version. You will be able to choose which components to download and install.
Alan
Post by Alan »
I can not use the trial version of Ocean Mind as I have tried it in the past and the trial period is long over. I also can not do the online install as my home computer is not connected to the internet. I was trying to get the help file so it could tell me how the features I am testing are supposed to work. I have copied the list of new features for the Beta version off your web site to do the same thing.
You can use the install of Atlantis Ocean Mind as many times as you need (even if Atlantis itself says that your copy of Atlantis has expired).
Simply use any of the setup files of Atlantis Ocean Mind to install it to your PC. The Help file of Atlantis would be installed too. You could copy this Help file to your home PC.
But the Help system of the latest public version of Atlantis Ocean Mind (1.5.1.4) does not include information regarding the new features available in the latest beta. The new features are currently explained only on the Betatesting News page.
You might also read the Chronicle of Changes pages. They describe many features of Atlantis Ocean Mind with a greater precise.
Alan
Post by Alan »
Thank you. I will do as you have pointed out.
