Spellcheck dialog font size
Alan
Post by Alan »
Is there a way to increase the dialog font size for the spellchecker? I have trouble reading the small characters that are in it for the word being corrected and the words given as suggestions.
The next build of Atlantis Ocean Mind (1.5.0.2) will use a larger font size. It should be available in a few next days.
denis martindale
VisToolBox Magnifier option for general use
Post by denis martindale »
http://vistoolbox.com/VisTb.htm
You can try out this free download to help magnify a set area onscreen eg x2, x3, x4 resolution. The VisToolbox can check colour codes and can copy an area onscreen. Copy to clipboard means you can resize the screenshot in a graphics program like Paint Shop Pro...
There is a HOT KEY choice to magnify eg set up as ALT+M and once the program is running, the ALT+M action can boost forum displays as the screen magnification area is moved across the screen...
It will boost even this message as I'm typing it in the small font accepted by the forum. Click ALT+M again to remove the magnification display...
The Atlantis magnification goes up to 500% yet with the VisToolbox magnifier program you can boost that, too!
The VisToolBox magnifier helps to view the top Menus command text info, too. They are quite small font sizes, aren't they? Will they also be updated? If not, then the VisToolBox program will help.
