Cursor,
Eric Gibson
Cursor,
Post by Eric Gibson »
Any way to get a fatter cursor in Atlantis??? Also, I'd like to turn off that aggravating 'left or right justify" (or whatever you call) symbol that seems to pop out from the cursor every time I move the cursor toward the margins. otherwise. . . great program! thanks, eric
BuffyBot
Cursor,
Post by BuffyBot »
Eric Gibson wrote: Also, I'd like to turn off that aggravating 'left or right justify" (or whatever you call) symbol that seems to pop out from the cursor
Uncheck the option "Enable Click & Type" and Atlantis won't show these.
Bigger and thicker carets (cursors) are displayed for bigger font sizes and zoom factors.
If the current font size is small, the caret is small and thin too.
