Word Spacing Missing!
dec
Post by dec »
Hi there
Although I am extremely happy w Atlantis about almost everything, I just found a critical error/omission when creating docs/reports.
Although you have character spacing (and kerning), you do NOT seem to have realised that, apart from a separate need for WORD spacing - possibly greater than character spacing - character spacing actually makes the need for word spacing even MORE critical.
Why is this critical small text adjustment function not there, when you have character spacing which is less necessary, and actually makes the situation WORSE.
Kind regards
Dec Sites
Re: Word Spacing Missing!
I am sorry, but there is no such font formatting option in MS Word documents as "word spacing". You can, however, change the "character spacing" for the space characters themselves. To do so, select all the space characters in your document using the "Find/Replace" tool, and apply a different character spacing to the selection.
