PDF files produced with Atlantis: Problem with hyphens
smitchell
Post by smitchell »
I have a DOCX file created with Atlantis 5.0.0.1 with hyphenation enabled. When viewing the document in Atlantis, some words are hyphenated at the right margin. When the document is saved as PDF, the hyphens do not display but the words do split at the right margin.
Otherwise the PDF output is excellent.
Re: PDF files produced with Atlantis: Problem with hyphens
This will be fixed in the next build of Atlantis. Sorry for this. Thanks for reporting this.
smitchell
Post by smitchell »
Thank you for the quick fix in version 5.0.0.2! The problem is now gone.
