Atlantis v. 5.0.0.1
In searching for the straight double quote (decimal 34) I discovered that the search is stopping on the straight single quote (decimal 39).
I did not investigate further.
Search/Replace Error
Re: Search/Replace Error
When the "Exact match" option is unchecked:
all types of quotes, both single and double, match. In the next build, there will be a distinction between single and double quotes.
Oh, I see. I was not familiar with that behavior. Thank you.
