How to prevent text such as "10/16" from displaying as a fraction by default
Ryan1
Post by Ryan1 »
When I enter the following text in an RTF document in AWP "10/16" it automatically displays as a fraction (screenshot below) instead of as it appears here in this sentence.
Is there some setting I can set to prevent similar entries from appearing as a fraction and have them appear as in the previous sentence by default?
Sorry, I looked for a setting, including in the Spell Checker, but could not figure out how to do this. It's even possible I set it to do this at one time myself in the past, but I don't remember doing it.
Thanks for your help!
Screenshot of the fractional display:
rstroud
Re: How to prevent text such as "10/16" from displaying as a fraction by default
Post by rstroud »
Interesting phenomenon. I could not reproduce it.
Atlantis has an option (Tools > Autocorrect Options) to produce fractions from things like 7/8 or 2/3. But I could not get it to work for numbers greater than a single digit.
Does it do this for other fractions like 11/13 or 10/19?
You can create a real fraction by superscripting and subscripting the numbers 10 and 16, respectively, and then inserting a / that you have copied from a real fraction like 7/8.
But I do not know how you could have made Atlantis automatically replace every instance of 10/16 with the real fraction. I tried and could not do it.
To state the obvious, and I know you have probably done this, make sure that the option to create real fractions is unchecked, and see if anything changes.
Ryan1
Post by Ryan1 »
rstroud wrote: Fri Aug 15, 2025 4:00 pm Atlantis has an option (Tools > Autocorrect Options) to produce fractions from things like 7/8 or 2/3. But I could not get it to work for numbers greater than a single digit.
That is the answer! I forgot that option and overlooked it.
When I have it checked even two digit numbers such as 56/98 produce fractions. In fact it produces fractions with any number of digit numbers. But when I uncheck it, nothing produces a fraction (unless I do it manually with super/subscripts).
Thanks for the reminder. It works! :D
What is your Atlantis version?
rstroud
Post by rstroud »
In my case, Atlantis is completely up to date at version 4.4.6.4.
I should have included that information. Sorry.
Windows (version 11) reports that my system is up to date. I checked the fractions issue again just now. Single-digit numbers like 7/8 will convert to a real fraction. But something like 11/17 will not.
Ryan1
Post by Ryan1 »
admin wrote: Sat Aug 16, 2025 7:00 am What is your Atlantis version?
Have not updated in a while. I'm using v4.1.4.7.
This is a quite old version. The "Format fractions ..." option of the AutoCorrect in more recent versions of Atlantis applies only to single digit fractions.
Ryan1
Post by Ryan1 »
Ahh thank you! Will update as soon as I get a chance.
