ver.4.4.6.1 /???????
Oaks
Post by Oaks »
I am deaf blind . I was using my program and I drop the mouse and lost the Icon that go tith file , edit , etc.
Now I have a new problem the new ver. is black and grey and i csnot see anything on the screen AND None of my
articles are open and when i try to open n item it tells me the app. is npt istalled open it
sorry about spelling
Re: ver.4.4.6.1 /???????
If you accidentally deleted the Atlantis shortcut (icon) on the Windows Desktop, you can run the setup file of Atlantis, and it will create the icon for you.
The dark background may mean that your Windows, or Atlantis, or both are in the Dark mode. You can switch among the color modes in Atlantis through the "View | Color Mode" command of the main menu of Atlantis.
