In Polish, we have various abbreviations that end with a dot. For example:
itp. - And similar ones
np. - For example
ul. - Street
r. - year
pt. - under the title
When I use them in the middle of a sentence, Atlantis automatically capitalizes the next word. It can be very annoying.
Disabling capitalization after using Polish abbreviations
Re: Disabling capitalization after using Polish abbreviations
For me this does not happen (fortunately).rafal wrote: Wed Oct 16, 2024 3:17 pm When I use them in the middle of a sentence, Atlantis automatically capitalizes the next word.
Please take a look at Tools --> AutoCorrect Options. The box for "Capitalize first letter of sentences" must be unchecked in order to avoid what happens to you. (A dot is regarded as a punctuation mark that finishes a sentence - even if in some cases, like abbrevations, it has another meaning.)
Do not disable "Capitalize first letter of sentences". Use the “Exceptions…” button to the right of that option, and enter the various abbreviations that end with a dot in Polish.
Of course, do this for the AutoCorrect Options associated with the Polish language (Polish language shown in the Atlantis status bar).
I admit that I was not aware of this possibility with the exceptions. Sorry.Robert wrote: Wed Oct 16, 2024 4:35 pm Do not disable "Capitalize first letter of sentences". Use the “Exceptions…” button to the right of that option, and enter the various abbreviations that end with a dot in Polish.
Thanks for your help. I can add exceptions myself, but maybe they should be added by default for Polish autocorrection.
The AutoCorrect data built-in into Atlantis does not include the Polish resources. If someone composes them, they could be added to Atlantis. But the “capitalize” exceptions are a very small part of the AutoCorrect data set for a language. The “replace with” pairs are a much bigger part.
And how to prepare these Polish resources for AutoCorrect? Maybe I could help with that.
The "replace with" AutoCorrect data is just a plain text file. One "replace with" item per line. A tab character between the "replace" and "with" parts. Attached the default "replace with" items for the English AutoCorrect.
- Autocorrect_ReplaceWith_EN.txt
- (63.44 KiB) Downloaded 547 times
