Updated template
lynneconnolly
Updated template
Post by lynneconnolly »
I've updated my default template to use a different font. Is there a way that I can apply the new version to older documents?
Lynne Connolly
Re: Updated template
Atlantis uses document templates to create new documents. Modifying a document template would not affect existing (older) documents.
If you do not have many older documents, you can open them in Atlantis, and for each document press Ctrl+A, and apply the new font.
