AutoCorrect options window no longer appears (Windows 7)
JPh1
Post by JPh1 »
When I launched AutoCorrect in the past, a window would come up with several options, including the very useful one that would auto-correct the whole document at once.
That window options doesn't come up with 4.3.3.0 (on Windows 7).
Instead, AutoCorrect starts and hangs. The message "Performing Autocorrect..."appears on the status bar, and I need to hit Esc to stop it.
Re: AutoCorrect options window no longer appears (Windows 7)
Please launch a test copy of Atlantis with factory settings, and click the AutoCorrect command. If the AutoCorrect dialog pops up, the problem is linked to your current Atlantis settings. In this case, please email your Atlantis settings file ("My documents\Atlantis\Atlantis.ini") and the document file you want to AutoCorrect to support@atlantiswordprocessor.com.
JPh1
Post by JPh1 »
Dialog pops up with Factory Setting. I'll send the appropriate files to support. Thanks
UPDATE: Now that I've reinstalled V4 I get the AutoCorrect window even without Factory setting. So I'll hold on to that for now.
Maybe the problem was triggered by a specific document. I suppose you have performed these tests on same document.
Anyway, please try to avoid mixing different versions of Atlantis.
