Compliments on Your Help System
freecicero
Post by freecicero »
Over my years in using Atlantis I have noticed that you have a very responsive and useful forum using phpbbs.
I also very much like your help system, but in looking at it and the page source I am not able to determine how you generate it.
Would you mind stating the program or system or template that you use to generate that (so I might consider it for a separate project I have in mind)? I have been exploring Docusaurus and Mkdocs and similar methods and I am wondering if you use one of those or something else.
thanks!
Re: Compliments on Your Help System
Sorry, but there is no template or system or program. There is a set of scripts created specifically for this site.
freecicero
Thanks for your reply. You guys do a great job in making everything you do look professional.
Thank you.
