UK spellchecker
John Stafford
UK spellchecker
Post by John Stafford »
Using the UK spellchecker, I am getting some common words flagged, for example, "outline" and "give." Is this a limitation or is something amiss? Using latest Atlantis. John
These words are contained by the English dictionary. They should not be reported as misspelt.
Are you sure that they are marked as belonging to the English language? Try to click any of these words, then choose “Format | Language Coding…”. This dialog should say “English (UK)” or “English (US)”.
Also does your English spellchecker include the required (original) dictionaries (lexicons) “english.zlx” and “uk.zlx”. Choose “Tools | Options”, “Spellcheck”, “Spellcheck Systems & Dictionaries…”.
