Editing Restrictions for Other Users
Qwertyportne
Post by Qwertyportne »
I sent a DOC file to a friend but she was unable to edit it because the file was set to restrict editing by other users. So I brought up the Properties for my file but couldn't find anyway to remove the restriction. Sure would appreciate help on this. Thanks!
rstroud
Re: Editing Restrictions for Other Users
Post by rstroud »
Check the following.
Open whatever file manager you currently use (e.g., Windows Explorer).
Find your file.
Right-click on it.
Click Properties.
Look to see whether "Read Only" is checked. If it is checked, remove the check.
Maybe that will solve the problem.
