quotes
kyknos
quotes
Post by kyknos »
how to stop atlantis from inserting spaces between quoted text and quotes themselves? if i use auto "smart quotes" feature, it not only "educate" quotes, which is GOOD thing, but also insert the (half) spaces, which is BAD thing, at least in czech language
Atlantis might insert spaces before/after smart quotes if the "Smart Space Management" options ("Tools | AutoCorrect Options...", "Rules...") say that these smart quotes require spaces before and/or after.
You might need to adjust these options. By default, Atlantis insert spaces before opening "French" quotes and after closing French quotes but for the French language only.
kyknos
still problem
Post by kyknos »
in latest version (7) of atlantis, there is still a problem
i got rid of these spaces by deleting smart quotes from space management list... it works this way
but if i turn whole space management off (and leave quotes in the list), it inserts the spaces!!! i swear!
You are right. I assume that only a few tried to adjust the “Smart Space Management” options of the Atlantis AutoCorrect. A fix will be included to Atlantis Ocean Mind 1.1.2.8. Thanks.
Kyknos
i wont use Atlantis until 8 is released
Post by Kyknos »
or there is a danger i find so many bugs it could not be ever completed))))
despite the bugs, it is great program :)
