Making a list, checking it twice. Putting it in alpha order?
Mandolina
Post by Mandolina »
:?: Hello.
I want to type up a simple list and have it put into alphabetical order. This is NOT a table of contents and does not need hyperlinks. I've tried to find such a thing in the help menu but have not found it.
Is there a way I do this with Atlantis?
Atlantis has the "Sort Paragraphs" feature.
Just select the desired paragraphs (your list), then use the "Edit | Special | Sort Paragraphs (Ascending)" menu command.
Mandolina
Post by Mandolina »
:D Thank you Thank you! :D :D
Your support is excellent and so is your word processor. I wouldn't exchange it for anything mr. gates could come up with. ;)
