Separate hotkey for the newer Control Board Find/Replace?
graatch
Post by graatch »
The new control board find/replace is useful, but equally or more often I want to use the find/replace dialog. At the moment it seems using the menu on the little gear in the control board is the only way to switch between them. I wonder if they might be separated out with an option for a separate hotkey, so that I could ctrl+f for one and [whatever key combination] for the other.
You can make the dialog your default search tool. Just click that "gear" button, and uncheck the "Use Instead of 'Find/Replace' Dialog" option. Pressing Ctrl+F or Ctrl+H would then display the dialog not the Control Board panel.
graatch
Post by graatch »
Ah that works fine, yes. Thank you.
