Document Folder
christinerubinace
Document Folder
Post by christinerubinace »
Is there a way to create another Document Folder? I would find it easier if I had a Document Folder just for my Atlantis Docs.
The default document folder in Atlantis is "My documents\Atlantis\Documents". So it is for your Atlantis documents by default. But you can create another folder with your file manager, then specify it as the document folder in Atlantis (click the "Browse..." button on the "Load/Save" tab of the "Tools | Options..." dialog of Atlantis).
