Password
Re: Password
Password? But Atlantis never asks for any passwords.
Max_Quordlepleen
Re: Password
Post by Max_Quordlepleen »
Maybe it's asking for your registration code if you've downloaded Ocean Mind, the shareware version, rather than Nova, the freeware version?
Salaam alaikum, noho ora mai
Re: Password
A-ha! I think I know the reason. You have specified the Encrypted Document (COD) format as your default document format. So each time you launch Atlantis, it creates a new encrypted document, and asks you to specify the password which you wish to use for this encrypted document.<br><br>You should specify another default format (for example, Rich Text Format). For this choose the File&#124;New&#124;Formats & Templates... main menu command, then select the Rich Text Format item from the Default Format for New Documents list box. Click the OK.
