Avira constantly marks Atlantis updates as a dangerous virus. I create an exception, but it won't take it.
I can handle the annoyance, but I needed to let you know, because this might put people off getting Atlantis, which would be a shame.
Atlantis and Avira
BitDefender is having the same issues with Atlantis. Nowadays, most antivirus software rely on a database of well-known applications. When an application is not ranked within their “big-names” database, they assume it is potentially harmful. This is Artificial Intelligence at its silliest!
Note that it might help to add the whole folder path to Atlantis (with asterisk) to the Avira exclusion list:
"C:\Program Files\Atlantis\*" on a 32-bit system
"C:\Program Files (x86)\Atlantis\*" on a 64-bit system
avast saying is generic virus
avast is now reporting this setup program
is a virus.. aries.generic
didnt on .4 but .5 it does
lynneconnolly
Re: avast saying is generic virus
A reply from Avast:Breew wrote:avast is now reporting this setup program
If the problem reoccurs, could you please make a screenshot and send it to us or directly to Avast?The provided file doesn't seem to be detected by Avast. Could you please send us a screenshot of the detection message you're getting? https://support.avast.com/en-ww/article ... screenshot
lynneconnolly
