Windows Flip 3D?
ckent
Windows Flip 3D?
Post by ckent »
I just thought I'd bring this to your attention...
I'm using Atlantis 1.6.5.2 beta b1 in Windows 7 x64, and I noticed that when you use Windows Flip 3D (alt + windows key), Atlantis disappears and is not one of the windows/programs you can move to. Regular windows flip (Alt + tab) works fine though.
Re: Windows Flip 3D?
ckent wrote:when you use Windows Flip 3D (alt + windows key), Atlantis disappears and is not one of the windows/programs you can move to.
The regular hot key for Flip3D is “Windows Key+Tab”, not “Alt+Windows Key”.
The Flip 3D function does not work correctly with Atlantis when it is minimized to the Windows Taskbar. If your restore the window of Atlantis from the Taskbar, it should work with the Flip 3D correctly.
This limitation is caused by the specifics of the main window of Atlantis. We will try to lift this limitation in the future.
We are sorry for the inconvenience.
