No spellcheck system is installed
Prince
Post by Prince »
Guess we had this problem &nbsp;before long ago. But I do not remember the solution.<br><br>I have installed OM at the new PC in the office - no problem at all - and yesterday the spell checker. But when trying it there is the information "No spellcheck system is installed for language Deutsch (Deutschland)"<br><br>How can I fix this? Thank you
Just call me the Prince
Re: No spellcheck system is installed
The German spellchecker is not a part of the standard Setup file of Atlantis Ocean Mind. You should download the Setup file of the German spellchecker from this page:<br><br>http://www.rssol.com/en/html/download/spellcheck.htm
1953
Post by 1953 »
When we update Atlantis is the British English spell checker automatically updated?<br>
If the "British Spellchecker" component of the Atlantis Setup is checked (the Setup has a special page - "Components"), and the Setup file contains updated spellchecker files, they are installed of course. Your personal spellcheck dictionaries are not affected.
By the way, the incoming minor release of Atlantis (1.1.1.x) will include new improved English spellcheckers.
Prince
Post by Prince »
Before I posted I have downloaded and installed of course the spellcheckers for german and british english. The asc-files are in the folder "Spellcheck" as usual.
A very important note: you should close all running instances of Atlantis (if any) before installing a spellchecker addon. Atlantis does not automatically use all the ASC files from the "Atlantis\Spellcheck" folder. They should be properly installed. You should either use the desired spellcheck setup again (do not forget to close Atlantis), or choose the "Tools &#124; Options" -> "Spellcheck" -> "Spellcheck Systems and Dictionaries" to install the desired spellcheck systems manually.
Prince
Post by Prince »
It works!!!
