Document opening problem
Peter Merton
Post by Peter Merton »
I had a strange thing happen with Atlantis. Four documents were open simultaneously and I was working on each one in turn. I had the Document Bar activated to facilitate changing quickly between documents. (Wonderful feature!) Whilst working I saved periodically out of habit, and at the end of the session closed Atlantis. All documents had been left open with their respective cursors at different points within each document. When I came to open Atlantis the following morning a message came up saying Atlantis could not open the documents.
I pressed Escape until eventually the message disappeared, and then selected the four documents and opened them simultaneously without a problem. This has never happened before. Was there a particular reason for this? All four documents’ names started with the same fours letters, followed by differing letters thereafter to identify them. :?:
Can you recall the exact message displayed by Atlantis?
Peter Merton
I have just tried to get the problem to occur again. It did not. So let's leave it for now. If it happens again I'l make a note of the message. Regards, Peter.
