Color menus are empty for fonts and highlights
Laren
Post by Laren »
This problem happened once before and I can't remember how I fixed it. It happened all of a sudden then and now, and all I remember is that it left me with a headache from banging my head against my computer!
TIA,
Laren [aka sandman]
You could try either of the following:
1. Close, then reopen Atlantis.
2. Switch the Atlantis toolbars off, then back on.
3. Log off Windows, then log back on. Reopen Atlantis.
4. Reboot, then reopen Atlantis.
Hope this helps.
But, please, do mind your head!
Laren
Re: Color menus are empty for fonts and highlights
Post by Laren »
Robert wrote:Hi,
Hope this helps.
Robert, that is what I call real help!! I posted, had lunch, came back, and there was my answer. Before I posted, I uninstalled, re-installed, and tried your 1, 2, and 4. Logging off and back on did the trick. I'll try that with other program problems, too.
I don't post here often, but I do monitor the forum. I am continuously impressed with your help to others and with your patience, Robert.
Thanks,
Laren
