Font/Size
medion
Font/Size
Post by medion »
If I open a blank document and click change font and/or font size, it shows the font/size in a separate window. But if I right click a blank document left click font and change the font not the size and then go back to a blank document, then click font/size a blank window appears but the font/size does not appear in the separate window. I have not noticed this before. Is this a bug or normal ?
Many thanks.
When you have a selection in your document, and this selection includes only space characters or special symbols (for instance, paragraph end marks), the "Format | Font..." dialog displays a blank preview indeed. This glitch will be fixed in any next release of Atlantis. Did you mean this glitch?
medion
Post by medion »
Yes. Thank you.
