Ini in Notepad
harolnick
Ini in Notepad
Post by harolnick »
Easy copying Atlantis from Windows 7 to Windows 11. But to save resetting time, I wanted to copy Atlantis.,ini. But didn't find it on Windows 7. I did find Atlantis.notepad, which seemed to have the right setting directions, but unsure. Can I rename Atlantis.notepad to ini.notepad and hope for the best? Or how can I confirm the Atlantis.notepad info? Many thanks.
Re: Ini in Notepad
The configuration file of Atlantis is named "Atlantis.ini", not "Atlantis.notepad". In Windows 7, you will normally find it under "C:\Users\<your_user_name>\My documents\Atlantis".
Please also read this article:
https://www.atlantiswordprocessor.com/e ... rating.htm
