get rid of pesky tabs
Ambaquista
Post by Ambaquista »
Sometimes I have to work with imported files (doc or docx) with many tabs spread across the document. How can I erase (or replace) all at once, instead of traveling the entire document looking for and replacing each ones?
Re: get rid of pesky tabs
You can use the Find/Replace tool of Atlantis:
1. Press Ctrl+H.
2. Type ^t into the "Find what" box.
3. Type a space character into the "Replace with" box, or leave this box blank.
4. Click "Replace All".
