How can I remove these groupings?
Ryan1
Post by Ryan1 »
Sorry for the Subject wording on this but I don't know what these are called.
Sometimes when I copy text into a document it creates these "groupings" with the '-' and '+' symbols that I do not want. (please see screenshot below)
I once figured out how to remove them, but forgot what feature this is or how to do it.
Thank you for your help.
Screenshot - 3_28_2025 , 10_59_26 AM.png (820 Bytes) Viewed 8682 times
Re: How can I remove these groupings?
I suppose you mean the "collapsible headings":
https://www.atlantiswordprocessor.com/e ... adings.htm
You can configure the feature on the "Edit" tab of the "Tools | Options..." dialog:
https://www.atlantiswordprocessor.com/e ... tm#colhead
Ryan1
Post by Ryan1 »
Thank you for those references, they helped me understand this feature much better.
It's a great feature so I don't want to disable it. I have a much better understanding of it now so I know how to activate it when needed.
I determined that what I needed was the 'Convert heading(s) to body text' button in the 'Headings' section on the 'Control Board' panel. I wanted to be able to remove certain headings that appear sometimes unexpectedly when I copy text into my documents without losing the text. This did the job!
Thanks again!
