Atlantis Word Processor 4.3.8 (beta)
Atlantis Word Processor 4.3.8 is available for betatesting.
This version has a reworked tool for creating tables of contents. It adds support for creating tables of contents from custom styles and direct outline levels of paragraphs, and introduces advanced methods for creating multiple tables of contents in same document:
You can find details here.
Setup file of Atlantis Word Processor 4.3.8.0 (size: 2.8 MB) (build a8, released on Mar 30, 2024)
