Losing Formatting
wildchild1954
Losing Formatting
Post by wildchild1954 »
The main text I work with is as follows:
Font: Garamond 12 point
Paragraph: Justified
First Line Indent: 0.2
Line Spacing: Multiple 1.15
However, every document I open the text is:
Paragraph: Left
Line Spacing: Single
This occurs whether I open an .rtf or a .docx document. Is this occurring because I actually create the documents in Office 2007 Word or is there another explanation. I never had this problem with my original installation of Atlantis but every update it's gotten worse. Even if I modify what I have designated as Main style to the above parameters highlighting all the text doesn't change a thing. I have to highlight all of the text and then use the Paragraph to modify it to the correct settings.
How do I make Atlantis open documents with the correct settings for that document?
Re: Losing Formatting
Can you please post a document file that you think Atlantis does not open correctly? You can attach the document file to your forum post, or email it to support@atlantiswordprocessor.com.
