Bug in Atlantis
rstroud
Bug in Atlantis
Post by rstroud »
Hello, all ...
I believe that I have discovered a bug in Atlantis (version 5.0.0.3).
I checked this carefully, and I have no recollection of ever seeing this behavior before.
DESCRIPTION
  • You create a Style, based on Normal, and use it to tag some paragraphs. Everything works fine.
  • Then you decide to change the name of that Style, and you make the change.
  • The Style name changes, but the Style loses its formatting characteristics and reverts to Normal.
Thoughts?
Alan
Re: Bug in Atlantis
Post by Alan »
Hi rstroud,
Does the created Style lose all its formatting after being name changed or do the paragraphs set to that original paragraph style change to the Normal paragraph style? I have noticed that when a paragraph style has a name change those paragraphs of that style not selected will change to the based on paragraph style as if that original name paragraph style had been deleted. If all the original name paragraph style paragraphs are selected and then after changing the name that is applied on exit all will be as you set and named.
Alan
Atlantis 5
rstroud
Re: Bug in Atlantis
Post by rstroud »
To be more specific: What happens is that the created Style still exists, now under a new name. You can look at the code for it, and the code is there. You can even apply the Style to any paragraph, and it will work.
But the paragraphs that had the same code, under the old name, revert to the formatting associated with Normal.
It is always difficult to explain these things.
Just open a new document and create one new Style, based on Normal. Use this new Style on a paragraph. It will work fine.
But now change the name of the newly created Style. Your paragraph will lose its formatting and revert to Normal format.
The new Style that you created and renamed can still be used, but it has to be applied again to every paragraph to which it was attached.
Maybe this has always been Atlantis behavior, but I doubt it. I have done name changes a zillion times, and I do not think that they were all with LibreOffice Writer, which I also use.
Alan
Re: Bug in Atlantis
Post by Alan »
Hi rstroud,
I have noticed that exact same behavior for years. My thought is that when the name is changed the software behaves like all the paragraph styles with the old name had that style deleted instead of applying the new name to them. When a paragraph style is just deleted all the paragraphs with that style change to the style it is based on.
Alan
Atlantis 5
Re: Bug in Atlantis
This bug is not that old. Fixed in 5.0.0.4. Please check for updates. Thank you.
rstroud
Re: Bug in Atlantis
Post by rstroud »
Everything is working fine now, just as in the past. Thanks!
Now I can get back to working on my "how to" article on how to create and use Styles in Atlantis.
I knew I was not crazy. :D
