Invisible Sound Volume (v4.4.1.10)
leifel
Post by leifel »
Just want to let you known that the option for the new "Sound Volume" as introduced by v4.4.1.10 and described at https://www.atlantiswordprocessor.com/e ... _1_010.htm is outside of visible area when you run with a high resolution display with large zoom factor on Windows 11. On my screen, with Windows 11 Zoom-factor of 150% the options dialog looks like this:
(Not possible to paste an image here!?)
Point is, the slider-control (and its title text) to adjust the volume is outside of visible area of the dialog box, and the dialog box is not resizable.
Re: Invisible Sound Volume (v4.4.1.10)
This will be fixed in the next release of Atlantis. Thanks.
Images can be attached to a forum post. Or you can insert a link to the image.
