Unwanted typewriter sound
rstroud
Post by rstroud »
I think this must have happened with the last update to Atlantis.
I noticed that when an automatic line wrap occurred, I was getting some kind of typewriter sound (maybe an imitation of a carriage return?).
Anyway, I checked Tools > Customize > Sounds. All the sounds were disabled. I discovered that the Error sound was also enabled, though it was not supposed to be. I did not check all the sounds.
I had to remove the default .asn file (using the window dialog) to stop the line-wrap sound. I did not check any of the other sounds after I removed the .asn file.
Just wanted you to know. :)
Re: Unwanted typewriter sound
Will be fixed. Thank you.
The Standard scheme does not include a sound for the "Error message" event. Even when sounds are enabled for a particular event, nothing is supposed to be played if there is no sound available for this event.
