Missing "File Associations" under "Tools"
Moonlight
Post by Moonlight »
According to the Atlantis Help* (and also to some postings here in the Forum) the option for creating or deleting file associations should be located at Tools --> File Associations.
*[https://www.atlantiswordprocessor.com/e ... uments.htm]
But I cannot find an element "File Associations" under "Tools". Has it been transferred somewhere else?
Re: Missing "File Associations" under "Tools"
Atlantis does not have the “File associations” command since 2022. The Help article will be updated. Thanks.
You can easily change the file associations with the file manager. Right-clicking the file and choosing the “Open With” command is probably the simplest way.
Moonlight
Post by Moonlight »
I see. Thank you.
