Outline view
JPh1
Outline view
Post by JPh1 »
I want to view only headings down to a specified level, as in Word Outline View.
To do this I Collapse All, which leaves level 1 headings. To see the level 2 headings of a level 1 heading I right click on that heading and Collapse. To see all level 2 headings, I first search for level 1 headings, select them all, and then Collapse. Ditto for other levels.
There must be a simpler way to do this, isn't it?
Re: Outline view
There is no option in Atlantis to automatically hide or collapse specific headings or chapters in the document window.
But you can specify which headings to display in the Headings panel of the Control Board. Just right click the "Headings" panel, and use the "Show levels" menu:
JPh1
Re: Outline view
Post by JPh1 »
Thank you. I added an Outline view in document window to Feature Request.
PS: I don't receive reply notification any longer
Re: Outline view
Did you check your spam folder? The feature seems to work correctly.
Re: Outline view
Please also check your notification settings for this forum.
JPh1
Re: Outline view
Post by JPh1 »
All working now. Thanks
fowlermattie
Re: Outline view
Post by fowlermattie »
I don't know, I just did everything the same as you.
