Eliminate Page Breaks?
Ryan1
Post by Ryan1 »
I'd like to use AWP for taking notes that are never going to be printed.
Ideally I'd like to eliminate page breaks altogether so that I can read the text onscreen with no breaks... like one long continuous sheet of paper.
The closest I could get to this was to make the page size longer with File>Page Settings>Page Format>Height
Only problem is that 22" is the maximum height I can set. After that it creates a page break.
Is there any way I can eliminate page breaks?
Thanks!
Why not use the Clippy Bank under the “View | Draft (Wrap to Window)” mode?
Clippy Bank
View modes
Ryan1
Post by Ryan1 »
Robert wrote:Why not use the Clippy Bank under the “View | Draft (Wrap to Window)” mode?
Clippy Bank
View modes
WOW! Perfect solution! Thank you very much. I had no idea this existed.
