I'm experiencing some erratic behavior with the AWP window (version 1.6.5.9 beta a5). With Windows Aero Flip 3D, sometimes the AWP does not appear in the cascading stack of windows. Other times, when AWP occupies the whole screen (not full screen mode) and you try to select a different application window in Flip 3D, the AWP window will appear on top. In other words, I cannot switch applications unless I use the task bar. Similar behavior occurs when using Logitech's Application Switcher (which is kind of like expose on a Mac).
I have seen other posts on related topics, but none with the latest beta release or with the Logitech Application Switcher. Any insights (or planned fixes?) on this matter would be appreciated.
Thanks,
Mike
