Closing all documents except the current one
At times, you might end up with many documents open in Atlantis, and realize that only one of them is actually needed. You probably will want to close all open documents except the current one. This is easily done as follows:
First, activate the document which you want to remain open in Atlantis. You can click its button on the Atlantis Document Bar, or click its name in the "Window" main menu list.
Then hold the Ctrl key down and click the "Close ALL documents" toolbar button:
Note. By default this command is available in the Alternative set of toolbar commands. So before pressing the Ctrl key, you might need to click the "Switch toolbars" button (the rightmost button on the toolbars):
Alternatively, you can hold the Ctrl key down and use the "File | Close All" main menu command directly.
