how to reload open documents?
I am using Atlantis Nova ver 1.0.0.35<br>I want to know one thing. When I open many documents in the document bar and later exit, I find that all the open documents are not there in the document bar. Instead Atlantis starts with its own new document. I want that the files that I have opened on the document bar should remain open even after I restart Atlantis Nova (ie Atalantis Nova should reload those documents onto the document bar when it is restarted). How can I do it ?<br><br>Anup<br><br>
Re: how to reload open documents?
This feature is available in Atlantis Ocean Mind only.
<br>I had once installed 'ocean mind', but have found that it plays around with the registries of .rtf files. So that when I uninstalled it, I found that the default rtf registry was gone and I had to repair it using the Office 2000 CD. Should a program make such changes without notifying the user or let the user decide what s/he wants to keep as default ?<br><br>Anup<br><br>
admin wrote:<br>This feature is available in Atlantis Ocean Mind only.<br>
The Setup file of Atlantis Ocean Mind has a special page - Associate. The Setup file asked you:<br>"Please check document types to associate with Atlantis Ocean Mind".<br>It suggested to associate Atlantis with RTF and COD file extensions. You agreed (clicked "Next").<br><br>The Setup file of Atlantis Nova does the same.<br><br>You simply should be more attentive.
<br>There is no such option in the setup of the Ocean Mind 1.0 (build 1.0.1.47). Are there new builds/versions that carry such options? Can you just write the link. Thanks.<br><br>Anup<br>--<br>
admin wrote:<br>The Setup file of Atlantis Ocean Mind has a special page - Associate. The Setup file asked you:<br>"Please check document types to associate with Atlantis Ocean Mind".<br>It suggested to associate Atlantis with RTF and COD file extensions. You agreed (clicked "Next").<br><br>The Setup file of Atlantis Nova does the same.<br><br>You simply should be more attentive.<br>
This option was available in all releases of Atlantis Ocean Mind including v. 1.0.1.47.<br><br>You could download the latest version – Atlantis Ocean Mind 1.1.
<br>There is no such option in Ocean Mind during the installation process whether in ver 1 or ver 1.1. Uptil just before the install, no such window comes up that says any such nice thing.I use win 98)<br><br>Anup<br><br>
admin wrote:<br>This option was available in all releases of Atlantis Ocean Mind including v. 1.0.1.47.<br><br>You could download the latest version – Atlantis Ocean Mind 1.1.<br>
Here is a screenshot:<br><br>
