Can anyone tell me the procedure for formatting block quotes in Atlantis.
Thanks.
Block quotes
There is no such element as block quotes in Atlantis documents. But you can change the left indent of the selected paragraphs by pressing the Ctrl+M keys. You can also change the space before/after your paragraphs.
It might be a good idea to create a new style "Block quote", and include all the required formatting into it. Please see the attached document. It has the "Block quote" style. This style sets the left indent of the "Block quote" paragraphs, space before and after, and font face. You create block quotes by applying this style to the required paragraphs.
Styles can be managed through the "Format | Style..." dialog of Atlantis, or the Styles panel of the Atlantis Control Board.
- Block quote.rtf
- (1.96 KiB) Downloaded 701 times
THANK YOU!!
Using Style and format I was able to create a block qutoe "style", assign it a hotkey and have indented left and right margins without even having to highlight the paragraph being edited - just put the cursor in it.
Atlantis IS the best!! Too bad I spend wasted money on "Flyword".
Thanks again!
Thanks again!
